Hot Topic (More than 10 Replies) Import Wpf Diagram (Read 14006 times)
Re: Import Wpf Diagram
Reply #15 - Mar 30th, 2009 at 3:04pm
It's 916 KB when I download it. Could you try again using some download manager or a different browser?
integragreg
Reply #16 - Mar 30th, 2009 at 3:06pm
I tried again, and got it this time. Thanks!
integragreg
Reply #17 - Mar 30th, 2009 at 6:42pm
Stoyan,
We saved a blank diagram using the Wpf components, and when we re-open it with DiagramLite, we get a null reference exception when calling the LoadFromXml() method.
Greg
integragreg
Reply #18 - Mar 30th, 2009 at 6:59pm
Sorry. False alarm. We weren't deserializing our tags.
It works fine.
integragreg
Reply #19 - Apr 6th, 2009 at 2:48pm
Stoyan,
The de-serialization of custom controls in DiagramLite seems to work okay for the first custom element that you encounter, but does not seem to work correctly for a second element.
Here's the repro:
We have a diagram with two custom controls inside the UIElement tag of two DiagramNodeAdapters. When we open it in DiagramLite, we handle the DeserializeControl as follows:
e.Handled = true;
   var elt = e.XmlElement.Elements().First();
   MyControl ctl = MyControl.LoadFromXml(elt);
   e.Node.Control = ctl;
We get a valid instance of our control back from our LoadFromXml() method in both cases. But later, when we try to access the second control instance using ControlNode.Control, we get an ArgumentException, saying that the specified argument was out of the range of valid values.
We've even tried inserting two ShapeNodes instead of MyControl in the DeserializeControl handler, and the same thing happens: we get the exception when we try to access the second control.
Reply #20 - Apr 6th, 2009 at 4:16pm
Do you mean there are two controls loaded successfully, but diagram.Nodes[1] throws an ArgumentException?
integragreg
Reply #21 - Apr 6th, 2009 at 4:27pm
There are two controls that are loaded successfully, but the following code throws the exception in the "if" statement on the second node:
foreach (ControlNode cn in diag.Nodes)
   try
   if (cn.Control != null && cn.Control is MyControl)
   MyControl ctl =cn.Control as MyControl;
  ctl.RegisterForChildAlarms();
   ctl.SetParent(cn);
   if (cn.Tag != null && cn.Tag is Diagram)
   WireEvents(cn.Tag as Diagram);
   catch
   continue;
Reply #22 - Apr 7th, 2009 at 3:01pm
We could not reproduce this with our test control. Could you email us the xml file and a small project that shown how you are trying it load it?
Thanks you,
