Normal Topic Grid - GetCellRow give me a wrog index (Read 3657 times)
alesdario
Feb 5th, 2009 at 10:53am
Hi stoyo. I've got a problem with
1) a LaneGrid method.
void flow_MouseClick(object sender, MouseEventArgs e)
                FlowChart flow = (FlowChart)sender;
                Grid grid = flow.LaneGrid;
                PointF clickPosition = e.Location; //click's position
                RectangleF rec = RectangleF.Empty;
                ICell cell = grid.GetCellFromPoint(clickPosition, ref rec);
                int indexSelectedLane = grid.GetCellRow(cell);
                if (indexSelectedLane >= 0)
                    string formatoTesto = "Arial";
                    grid.RowHeaders[indexSelectedLane ].TitleFont = new System.Drawing.Font(formatoTesto, 8, System.Drawing.FontStyle.Bold);
the index returns me grid.GetCellRow is always 1 or 0 even though my flow have more lanes and i click on the fourth lane.
2) is possible to insert new lane between two lanes?
tanks
Alessandro
alesdario
Re: Grid - GetCellRow give me a wrog index
Reply #1 - Feb 5th, 2009 at 11:09am
I think i've solved the problem ... MouseClick doesn't returns the position relative to the 0,0 point of the chart but it's relative to the 0,0 point of the displaied chart ... how can i solve ... ? mmm
Reply #2 - Feb 5th, 2009 at 12:19pm
1) Try converting e.Location to flowchart coordinates using the ClientToDoc method.
2) Version 5.2 adds InsertBefore and InsertAfter methods that will let you do that:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=123307034...
alesdario
Reply #3 - Feb 6th, 2009 at 10:13am
Stoyo wrote on Feb 5th, 2009 at 12:19pm:
it works. Tanks
Are there some incompatibility with 4.3 version?
Tanks for yours always very excellent support
Reply #4 - Feb 6th, 2009 at 10:30am
There are some differences.
alesdario
Reply #5 - Feb 6th, 2009 at 12:09pm
where can i find information about my license and his upgrade?
Reply #6 - Feb 6th, 2009 at 12:56pm
send me a private message with your company name and I will check in our records.
alesdario
Reply #7 - Feb 12th, 2009 at 8:59am
Now, i've got a new problem. When i select the right selected lane, i want to change her header background brush. I set the property
grid.RowHeaders[newIndex].Style.BackgroundBrush = new MindFusion.Drawing.SolidBrush(Color.DarkGray);
but it change not all header's area (for example only 50%, it depends to the mouseclick position). FlowChart grid seems need to be reloaded, how can i do this?
Reply #8 - Feb 12th, 2009 at 9:37am
Do you have some sub-lanes and child headers in the grid?
alesdario
Reply #9 - Feb 19th, 2009 at 8:49am
No, i don't
