Normal Topic Large number of nodes (Read 1778 times)
JC
Feb 5th, 2009 at 11:27pm
Hello All,
I'm researching some components I might need for an upcoming project and, never having worked with flowchart.net,  I have a question for the experts here.
* My project might require the ability to load a hierarchy type data set with up to 50k (simple)nodes.  Can Flowchart.net handle that type of node count with reasonable performance?
Thanks!
Re: Large number of nodes
Reply #1 - Feb 6th, 2009 at 9:07am
Here is some code you could play with:
Diagram diag = new Diagram();
diag.ValidityChecks = false;
diag.DefaultShape = Shapes.Rectangle;
DateTime start = DateTime.Now;
for (int i = 0; i < 50000; ++i)
	diag.Factory.CreateShapeNode(10, i*40, 30, 30);
MessageBox.Show("nodes created for: " + (DateTime.Now - start).ToString());
for (int i = 1; i < 50000; ++i)
	diag.Factory.CreateDiagramLink(diag.Nodes[i], diag.Nodes[i / 1000]);
MessageBox.Show("links created for: " + (DateTime.Now - start).ToString());
diagramView1.Diagram = diag;
Creating the 50000 nodes takes about 5 seconds on my system, and creating the 50000 links takes 15 seconds.
It's important that the diagram is not attached to a view while creating the items, or otherwise that would trigger many repaint events and slow down the Create calls a lot.
Note that creation time depends much on the structure of the graph. E.g. in my test if all 50000 links were connected to diag.Nodes[0], it took about two minutes. Seems it's a lot faster to update the link collections of size up to 1000 links for 50 nodes, than updating a single node's links collection with a size of 50000 links.
You might consider delay-loading your items, e.g. by showing only the first two levels of your hierarchy as Expandable nodes, and then create additional child nodes in response to the ExpandBtnClicked event.
JC
Reply #2 - Feb 6th, 2009 at 4:25pm
Thank you for your quick response Stoyan.
I expect that each of the 50,000 nodes will have anywhere from 1-100 links so lazy loading may be my only option for large data sets.
I'll give the code above a whirl to see how the number of nodes and links per node can affect performance then try to optimize from there.
- JC
