Normal Topic container node (Read 2222 times)
tmtton
container node
Feb 13th, 2009 at 8:44pm
Hi, when I enclose existing shape nodes within a container node, I can not select the individual shape nodes.
Re: container node
Reply #1 - Feb 14th, 2009 at 8:35am
What if you set container.ZIndex = 0?
tmtton
Re: container node
Reply #2 - Feb 14th, 2009 at 9:14pm
Thanks. Setting container z-index=0 lets me select the enclosed shape nodes.
I have another problem. Moving the container only moves some, and sometimes none of the enclosed shape nodes. How do I ensure that the shape nodes appear in the container are actually part of this container?
In our application, users can create an empty container and drag-n-drop shape nodes into it. They also want to create a new container and lay it over some (but not all) existing shape nodes in the diagram.
Re: container node
Reply #3 - Feb 15th, 2009 at 8:16am
Call ContainerNode.Add(node) for the nodes within the new container's Bounds.
