Normal Topic AttachProportional (Read 1931 times)
areddan
AttachProportional
Feb 17th, 2009 at 4:14am
Is there any way to "update" a group (or diagramnode) after I've attached items to it via this function?
The problem is it doesn't update those shapenodes I attach to be the correct size/position until I try to move the parent node.
Re: AttachProportional
Reply #1 - Feb 17th, 2009 at 8:30am
Set parentNode.Bounds = parentNode.Bounds to force the group to update.
areddan
Reply #2 - Feb 18th, 2009 at 12:17am
This works, if the parent can be cast to a node. What if it can't? Is there any way to update it via generic DiagramItem?
areddan
Reply #3 - Feb 18th, 2009 at 12:27am
Is it even an issue if the parent item is a link?
Reply #4 - Feb 18th, 2009 at 8:33am
Yes, it seems the control expects the parent to be a node in that case. The supported scenarios are the ones for which you can see DiagramNode.AttachTo overloads.
