Normal Topic using doubleclick event on link throws error ? (Read 3133 times)
jay
Feb 20th, 2009 at 7:15am
Hi stoyan,
             I have gone through one of the demos provided with JDiagram. In one example on double clicking a link enable a dialog to set the link lable.
             When I am trying to do same as following,
public void onLinkDblClicked(LinkEvent e)
DiagramLink arrow = e.getLink();
String newText = JOptionPane.showInputDialog(
this, "Enter arrow text", arrow.getText());
arrow.setText(newText);
it throws exception as,
java.lang.ClassCastException: com.mindfusion.diagramming.DiagramLink cannot be cast to com.mindfusion.diagramming.InplaceEditable
Thank you.
Re: using doubleclick event on link throws error ?
Reply #1 - Feb 20th, 2009 at 10:02am
Hi Jay,
Are you using the version from this thread now?
http://mindfusion.eu/Forum/YaBB.pl?board=jdiag_disc;action=display;num=123373245...
jay
Reply #2 - Feb 20th, 2009 at 10:26am
hi stoyan,
            Sorry i had not checked that reply, so i was using old version.  Now i am using that version and it is allowing inplace label editing for links.
I have followin questions regarding this feature;
1.  Can we disable inplace lable editing for a specific node.
2. How to change the border color for the inplace label editing box.
3. How Can i use a dialog instead of inplace editing on link double click.
Reply #3 - Feb 20th, 2009 at 10:43am
Hi Jay,
1, 3) DiagramView.setAllowInplaceEdit(false), and call DiagramView.beginEdit() from the doubleClicked event only for items you want enabled for editing.
2) Handle the enterInplaceEditMode event. It gives you a reference to the JTextArea used for inplace editing, and you can customize it as you see fit.
jay
Reply #4 - Feb 20th, 2009 at 11:14am
hi Stoyan,
            Thank you again, it worked for me.
