Normal Topic Node lables outside of ImageArea (Read 2301 times)
jaiswalamit
Feb 24th, 2009 at 6:39am
The DiagramLite is really amazing work and way to go.
One feature which I found lacking is positioning of node labels should be outside of the image area when a ShapeNode is used to show images as nodes. The TEXT property puts the image over the node which is not at all desired and readable and makes the whole diagram look ugly. I know, that usercontrol can be used as a workaround, but I believe you should make this feature an inbuilt finctionality in near releases please.
Amit
Re: Node lables outside of ImageArea
Reply #1 - Feb 24th, 2009 at 9:14am
Thanks 8) For the 1.0.2 release we'll try to implement support for ControlTempaltes that could be assigned to Shape definitions, and that should provide you with one way to move the text below the image. Additionally, there are text and image alignment properties in the Windows Forms version of the control, which we'll port to DiagramLite as well soon.
