Normal Topic What is th Shortcut key for "Undo"?? (Read 1412 times)
bemorem
MacPro Xeon Quad
Feb 24th, 2009 at 9:15am
What is th Shortcut key(Hot Key ?) for "Undo"??
If not exist, How to make the shortcut key for "Undo"?
We want the Ctrl+Z key ..
Thanks in advance ~
HW: MacPro Xeon Quad/ 4GB RAM&&OS: WinXP sp3 / .NET 3.5&&Dev: VS 2008 C# sp1&&flowchart .Net ver 4.3.x&&
Re: What is th Shortcut key for "Undo"??
Reply #1 - Feb 24th, 2009 at 9:23am
Add an undo item to your main menu, set its shortcut to Ctrl+Z, and call diagram.UndoManager.Undo from the event handler.
bemorem
MacPro Xeon Quad
Reply #2 - Feb 26th, 2009 at 11:38am
THanks
It Solved~
