Normal Topic Force grouping on layered layout (Read 1509 times)
choohj70
Feb 27th, 2009 at 10:02pm
Is there a way to force grouping in the layered layout? We are trying to create a dynamic time lapse swimlane.  If not, is there a way to add certain locational constraints to the layered layout calculation?
Thank you,
James
Re: Force grouping on layered layout
Reply #1 - Feb 28th, 2009 at 7:44am
It depends on what kind of grouping you need. Try calling the AttachTo method for some nodes while they are in the order you need them, and then call Arrange with the KeepGroupLayout property set to true. Is this close to your requirements?
