Normal Topic Readonly Diagram View. (Read 3133 times)
SandeepGowda
Mar 4th, 2009 at 1:42pm
hi,
Can we populate a Diagram view readonly, something
like user is not allowed to delete task,delete links but allow only select.
regards
sandeep
Re: Readonly Diagram View.
Reply #1 - Mar 4th, 2009 at 2:04pm
Set Behavior = Modify and DelKeyActyon = None.
SandeepGowda
Reply #2 - Mar 4th, 2009 at 2:38pm
hi,
can you please tell me which method is this DelKeyActyon = None.
regards
sandeep
Reply #3 - Mar 4th, 2009 at 2:57pm
It's a property of DiagramView.
Aziz ur Rahman
Reply #4 - Mar 7th, 2009 at 12:05pm
It is not a complete solution because user can still SELECT a node using mouse and resize it.
Can we really make the view READONLY? I tried to make Enabled=False but it will disable the scroll bars as well.
my current temporary solution is
Enabled=False
ResizeToFit()
Please post a complete solution
Syed Aziz ur Rahman
Reply #5 - Mar 8th, 2009 at 10:48am
You could use the DoNothing behavior. It will disable selection, but you could select nodes in response to the NodeClicked event. Another possibility is to use Modify, but call e.CancelDrag from the LinkModifying and NodeModifying handlers.
Aziz ur Rahman
Reply #6 - Mar 17th, 2009 at 10:31am
This solution will have one problem.
The user will not be able to modify any link or nodes but still he will see the anchors (i.e. he can select it) This will not look like a perfect readonly view. I have done one more thing. I have set all the items (links or nodes) to be locked.
  For Each item As DiagramItem In myDiagram.Items
         item.Locked = True
  Next
This will create a perfect read only view...
Syed Aziz ur Rahman
Reply #7 - Mar 17th, 2009 at 12:34pm
If you want to disable even selection of items, just set DiagramView.Behavior = DoNothing.
