Normal Topic Lanes & Export to PDF (Read 3227 times)
BidMaestro
to learn is to live
Mar 5th, 2009 at 12:06pm
Latest version 5.2
I have encountered a problem when exporting a  diagram containing lanes and a number of shapes to .pdf. The resultant PDF file is blank. I am using the latest pdfexport.dll (v 5.2.0.34178)
The export to Visio only exports the shapes
regards
Doug
Re: Lanes & Export to PDF
Reply #1 - Mar 5th, 2009 at 1:55pm
VisioExporter does not support lanes. Seems PdfExporter has some problem with the new feature where text can be displayed in the grid cells. The problem is that it expects some text to be set, at least a space, so as a work-around you could set the text of all cells in the grid like this:
grid[null, null].Text = " "; // a space symbol in the string
grid.TopLeftAreaText = " "; // a space symbol in the string
We'll try to fix this in the next couple of days.
BidMaestro
to learn is to live
Reply #2 - Mar 6th, 2009 at 12:37am
Once again; thank you. I am not in a hurry for this and will wait for the fix.
regards
Doug
ps. have a great weekend
BidMaestro
to learn is to live
Reply #3 - Mar 6th, 2009 at 1:09am
I forgot to mention taht I modified your suggested code for my VB testbed and it works fine when teh diagram is exported as a pdf file
[code]
For j = 0 To grid.ColumnCount - 1
           For k = 0 To grid.RowCount - 1
               grid(j, k).Text = " " '// a space symbol in the string
           Next
       Next
       grid.TopLeftAreaText = " " ' // a space symbol in the string
[/code]
Doug
Reply #4 - Mar 10th, 2009 at 11:44am
Hi Doug,
You can download a fixed version from the PM page. We are using a new naming convention for the assemblies now; you must remove the Flowchart.NET references from your project, and add references to the corresponding new assemblies.
