Normal Topic RouteLinks and AnchorPoint (Read 4305 times)
Hai
Mar 5th, 2009 at 4:38pm
Hi Stoyan
1.
I've tried to use the RouteLinks option but the result is very poor as you can see here http://www.oron-software.com/pic1.png
It seems like your Algorithm is acting weird ???
2.
And a question about the Anchors...
Is there a way to set an AnchorPoint to match only destination of a link and another one act as an Origin of a new link ?
This is important if the nodes are small and the direction is important.
I want one entry point for all the "incomming" links and one origin point for all the "outgoing" links
many thanks
Hai
Re: RouteLinks and AnchorPoint
Reply #1 - Mar 5th, 2009 at 4:45pm
Hi Hai,
1. Try this with a smaller RoutingOptions.GridSize, or otherwise the routing algorithm might consider these nodes to overlap at their closest corners.
2. The AnchorPoint constructor takes allowIncoming and allowOutgoing arguments.
Hai
Reply #2 - Mar 5th, 2009 at 4:56pm
I'll look into it, it sounds like what I need.
But what is "RoutingOptions.GridSize"
Where do I define it and what value should I give it ?
Should I give it the diagram size ? the size of the surrounding scrollviewer visible area ?
Can you please give me a sample code or snippet for that ?
Ill check the Anchors thing...
many Thx
Hai
Reply #3 - Mar 6th, 2009 at 1:14pm
Hi Hai,
RoutingOptions is a compound property of Diagram. You can use it like this:
diagram.RoutingOptions.GridSize = 4;
