Normal Topic selective inplacelabeleEditing ? (Read 3246 times)
jay
Mar 9th, 2009 at 9:25am
Hi stoyo,
      I want to know following things;
1. How to set inplacelabelediting enabled for link while disabled for nodes.
2. How to set inplacelabelediting enabled for few links while disabled for selective links.
     Thank you.
Re: selective inplacelabeleEditing ?
Reply #1 - Mar 9th, 2009 at 2:27pm
Hi Jay,
You'd have to disable the standard inplace editing mode (call setAllowInplaceEdit(false)), and start inplace edit operations by calling DiagramView.beginEdit() in response to the item's doubleClicked event.
jay
Reply #2 - Mar 10th, 2009 at 12:40pm
hi stoyo,
I have set standard inplace editing mode setAllowInplaceEdit(false), and on linkDblClickEvent
I am doing it like following;
private void onLinkDblClicked(LinkEvent e)
DiagramLink currentLink = (DiagramLink)e.getLink();
DiagramNode source = (DiagramNode)currentLink.getOrigin();
String nodeId = source.getTag().toString();
if(nodeId .equals("1")){
    diagView.beginEdit(currentLink);
but its not working...
Thank you.
Reply #3 - Mar 10th, 2009 at 12:48pm
beginEdit() is what the control would call internally when you double-click the link, and it's not likely that it wouldn't work. Are you sure 1 or "1" is set as a tag value for the origin node?
jay
Reply #4 - Mar 12th, 2009 at 11:06am
Hi stoyo,
          My method signature was wrong, so it was not calling. I corrected it, now it works fine.
Thank you .
