Normal Topic diagram.createImage(800,600) saves empty image ? (Read 2998 times)
jay
Mar 9th, 2009 at 11:50am
hi stoyo,
         I am using following way to save graph image as it was mentioned in one of the forum reply.
Image img = diagram.createImage(800,600);
          if (img == null)
                  JOptionPane.showMessageDialog(new JFrame(), "Error!!!");
          try {
                  // Save as PNG
                  File file = new File("C:\\Image.png");
                  ImageIO.write((RenderedImage) img, "png", file);
          } catch (FileNotFoundException e1) {
                  // TODO Auto-generated catch block
                  e1.printStackTrace();
          } catch (IOException e1) {
But it saves an image with white area and nothing else in it.
can you please explain, Where the things are going
wrong ?
Thank you...
jay
Re: diagram.createImage(800,600) saves empty image
Reply #1 - Mar 9th, 2009 at 12:47pm
   I have added diagramView to scrollPane and scorllPane to a Panel.
   it is looks like following;
Diagram Diag= new Diagram();
DiagramView diagView = new DiagramView();
diagView.setDiagram(Diag);
scrollPane = new JScrollPane(diagView);
mainPanel = new JPanel();mainPanel.add(scrollPane);
   Is this affecting any where to createImage() ?
Thank you
Reply #2 - Mar 9th, 2009 at 2:36pm
BufferedImage createImage(int pixelWidth, int pixelHeight) is an internal method, how have you managed to call it at all? You should use the no-args createImage() method instead.
jay
Reply #3 - Mar 10th, 2009 at 5:05am
Hi stoyo,
sorry , I was using diagram view method  diagView.createImage(800,600) ;
           Now I am using diagram.createImage() and it is working fine. But The image save shows a big image with minute node size. so the graph area is appearing wide and graph is appearing very small in it.  Would you please suggest how this could be overcome.
Thank you.
Reply #4 - Mar 10th, 2009 at 9:02am
Hi Jay,
Before exporting call setBounds with a smaller rectangle as argument or call resizetoFitItems.
jay
Reply #5 - Mar 10th, 2009 at 10:11am
Hi stoyo,
           This works exact as needed to save graph image.
Thanks a lot....
