Normal Topic Exception dragging a selection (Read 4709 times)
vtortola
Mar 12th, 2009 at 12:00pm
I get this exception when I do a drag select over a self-linked node like this:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at MindFusion.Utilities.ApproxBezier(Point[] points, Int32 startIdx, Int32 quality)
   at MindFusion.Diagramming.Wpf.DiagramLink.x506928df783c0c72(Int32 x949108ddd7122fd3)
   at MindFusion.Diagramming.Wpf.DiagramLink.xa170bf38e993d468(Rect x26545669838eb36e)
   at MindFusion.Diagramming.Wpf.Diagram.x98d300fb770bf5ec(Rect x26545669838eb36e, Boolean x201ab38fe5644146)
   at MindFusion.Diagramming.Wpf.Selection.AllowCreate(Point current, InteractionState ist)
   at MindFusion.Diagramming.Wpf.InteractionState.ValidateAndSetCursor(Point point, Diagram diagram)
   at MindFusion.Diagramming.Wpf.Diagram.OnPreviewMouseMove(MouseEventArgs e)
   at System.Windows.UIElement.OnPreviewMouseMoveThunk(Object sender, MouseEventArgs e)
   at System.Windows.Input.MouseEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
   at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
   at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter)
   at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.RunDialog(Form form)
   at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
   at System.Windows.Forms.Form.ShowDialog()
What is the problem? Any workaround?
I'd like sent you a XML with the diagram but is impossible save it as long I'm using pictures and non-serializable elements in the tags (would be nice have an option to ignore these elements).
Cheers.
Re: Exception dragging a selection
Reply #1 - Mar 12th, 2009 at 1:15pm
Does it happen if you draw the selection rectangle immediately after creating the self-loop link, or after you run your custom serialization code?
vtortola
Reply #2 - Mar 12th, 2009 at 4:20pm
Hi Stoyo,
1) I create a new empty diagram.
2) I add the self-linked table.
3) I apply the layout.
4) Close and save.
5) Open again.
6) I drag select over it.
7) crash.
If I omit the step 3 nothing happens.
If I omit the steps 4 and 5 nothing happens.
So seems like is something related with the layout and the deserialization with the self links.
Cheers.
Reply #3 - Mar 13th, 2009 at 12:07pm
OrthogonalRouter should set the link.Style to Cascading. Could you check why it is Bezier after deserialization? Also check if it has 3 * SegmentCount + 1 points in ControlPoints.
vtortola
Reply #4 - Mar 16th, 2009 at 5:35pm
It's a little bit strange. This is the obtained configuration for a self-loop link:
<Link Id="196">
<ControlPoints SegmentCount="3">
<Point X="262.5" Y="187.5" />
<Point X="262.5" Y="82.5" />
</ControlPoints>
</Link>
Makes sense for you?
I don't know where the Beizer stuff come from.
Find all "Bezier", Subfolders, Keep modified files open, Find Results 1, "Current Project", "*.vb;*.resx;*.xsd;*.wsdl;*.htm;*.html;*.aspx;*.ascx;*.asmx;*.svc;*.asax;*.confi
g;*.asp;*.asa;*.css;*.xml; *.xaml; *.cs;"
  Matching lines: 0    Matching files: 0    Total files searched: 20
Cheers.
Reply #5 - Mar 16th, 2009 at 6:56pm
CreateDiagramLink might automatically set the link.Style to Bezier if the origin and destination arguments are the same node. Could you set a breakpoint in your deserialization code and verify if that's what happens?
vtortola
Reply #6 - Mar 18th, 2009 at 12:41pm
Yes, something strange happens.
I create a link and is Bezier, I do:
link.Style = style;
Where "style" is "Polyline" ... but the property remains in "Bezier".
I hope this clue help you.
Cheers.
Reply #7 - Mar 18th, 2009 at 2:48pm
There's this code in the Style setter:
if (value != LinkStyle.Bezier)
     if (IsReflexive() && segmentCount < 3)
           return;
Seems you'll have to set SegmentCount = 3 before changing the Style of a reflexive link.
Cheers.
vtortola
Reply #8 - Mar 18th, 2009 at 4:55pm
I've done:
		link.Style = style;
		if ( link.Style == LinkStyle.Bezier )
		    link.SegmentCount = 3;
		    link.Style = LinkStyle.Polyline;
And seems to work.
Thanks.
