Normal Topic Split DiagramLink during Interaction (Read 1523 times)
jscott
Mar 13th, 2009 at 12:36am
Hi
I'm trying to support splitting a DiagramLink into segments as the user is creating it.
My behavior implements StartDraw, and in the situation where I wish to create link it does the following:
return gcnew InteractionState(gcnew DiagramLink(Diagram, node, a_point), -1, Action::Create);
This works fine for link creation in general.
In another place I respond to a key press event and do the following:
if (InteractionState ^interaction = Diagram->Interaction)
  if (interaction->Action == Action::Create)
    if (DiagramLink ^link = dynamic_cast<DiagramLink ^>(interaction->CurrentItem))
	link->ControlPoints->Insert(link->ControlPoints->Count-1, interaction->CurrentPoint);
	link->UpdateFromPoints();
This doesn't appear to influence the link during its creation as it remains a straight unsplit line. When the link is dropped on a valid anchor, the extra handles appear, but they don't appear in the correct places; they appear along the straight line, but they do break up the segment at the correct 'time'.
Is this something I could expect to get working easily? I know I can custom draw a link if necessary, but I had hoped this would be possible without doing so Smiley
Note that I only need to support Polyline at this time.
James
Re: Split DiagramLink during Interaction
Reply #1 - Mar 13th, 2009 at 8:18am
I can see your company has a license with source code. Replace the DiagramLink methods with the ones from this file:
http://mindfusion.eu/_temp/UpdateFromPoints.txt
Add a custom link class that looks like this:
class MyLink : DiagramLink
	public MyLink(Diagram parent) : base(parent)
	protected override void UpdateCreate(PointF current)
		ControlPoints[ControlPoints.Count - 1] = current;
		UpdateFromPoints(true, false);
	public void AddSegment(PointF point)
		ControlPoints.Add(point);
		UpdateFromPoints(true, true);
In the KeyDown handler:
if (diagram.Interaction != null &&
	diagram.Interaction.Action == Action.Create &&
	diagram.Interaction.CurrentItem is MyLink)
	MyLink link = diagram.Interaction.CurrentItem as MyLink;
	link.AddSegment(diagramView.ClientToDoc(diagramView.PointToClient(MousePosition)));
And enable drawing links from your custom class:
private void Form1_Load(object sender, System.EventArgs e)
	diagramView.CustomLinkType = typeof(MyLink);
	diagramView.Behavior = Behavior.Custom;
jscott
Reply #2 - Mar 16th, 2009 at 12:04am
That seems perfect, thanks for your help  Smiley
James
