Hot Topic (More than 10 Replies) Exception "shouldn't get here" (Read 4068 times)
mberger
Mar 16th, 2009 at 5:27am
When i load my diagram with loadfromfile, i get the exception "shouldn't get here".
... whats wrong?
Best regards
Marco
Re: Exception "shouldn't get here"
Reply #1 - Mar 16th, 2009 at 8:35am
This could happen if you are using a custom item type that implements its own serialization methods, and in SaveTo it writes a number of bytes different than the number it reads in the LoadFrom method. Another way this could happen is if you have a serializable type whose instances are used as Tag values, and again it saves more or less bytes than it loads during deserialization.
mberger
Reply #2 - Mar 16th, 2009 at 12:28pm
Yes, im add a custom item typ to me diagram. In the same way as in the IconNode sample described.
The only two differents between the example and my application is:
1.) i have added an additional property to my IconNode class.
2.) i have added a Tag to me Nodes
(for example Nodes(0).Tag = "PipeResistance")
Marco
Reply #3 - Mar 16th, 2009 at 12:33pm
Have you added a call to RegisterItemClass as in the IconNodes sample?
mberger
Reply #4 - Mar 16th, 2009 at 12:41pm
Yes i have...
FLowSim_Designer.diagram.RegisterItemClass(GetType(IconNode), "IconNode", 1)
Reply #5 - Mar 16th, 2009 at 12:46pm
Have you changed anything in the saveto and loadfrom methods?
mberger
Reply #6 - Mar 16th, 2009 at 1:03pm
No, ....
If i come back home, i will post the code of my IconNode class and the code how i add my IconNodes to the diagram.
Thanks for your help Stoyo!
Reply #7 - Mar 16th, 2009 at 1:13pm
Are you loading the file in the same application where you have saved it? If you need to use the same custom type in different applications, you will have to move it to a shared assembly, and call the RegisterItemClass method in both applications.
mberger
Reply #8 - Mar 16th, 2009 at 5:33pm
Hi here is the code of my application to insert a IconNode:
MainFrame
    Public Shared Sub Add_Inlet(ByVal sender As Object, ByVal e As MindFusion.Diagramming.DiagramEventArgs) Handles Add_Inlet_Event.Clicked
	  Dim IN_Inlet As IconNode
	  Select Case RT_Variable.QTY_Inlet_dyn
		Case Is >= 1
		    MiscFunctions.DesktopAlter("Fehlermeldung", "Es darf nur 1 Vorlauf pro Simulation definiert werden!")
		Case Else
		    'Einlass in Diagramm einfügen
		    IN_Inlet = New IconNode(FlowSim_Designer.Diagram)
		    IN_Inlet.Icon = FlowSim_Mainwindow.ImageList_DiagramNodes.Images(0)
		    IN_Inlet.Tag = "Inlet"
		    IN_Inlet.AnchorPattern = IconNodeProperties.INAP_Inlet
		    IN_Inlet.HandlesStyle = MindFusion.Diagramming.HandlesStyle.HatchHandles2
		    FlowSim_Designer.Diagram.Nodes.Add(IN_Inlet)
		    IN_Inlet.Move(e.MousePosition.X, e.MousePosition.Y)
		    'Eintrag im Projekt-Explorer
		    FlowSim_Designer.ProjectExplorer.Nodes(0).Nodes.Add("Inlet", "Vorlauf")
		    FlowSim_Designer.ProjectExplorer.Nodes(0).Nodes("Inlet").LeftImages.Add(FlowSim_Mainwindow.ImageList_TreeViewIcons.Images(2))
		    'Addiert einen Einlass zur Variable QTY_Inlet zum bestimmen der Gesamteinlassanzahl
		    RT_Variable.QTY_Inlet_dyn = RT_Variable.QTY_Inlet_dyn + 1
		    RT_Variable.QTY_Inlet_stat = RT_Variable.QTY_Inlet_stat + 1
	  End Select
    End Sub
mberger
Reply #9 - Mar 16th, 2009 at 5:36pm
IconNode class
Imports MindFusion.Diagramming
Imports MindFusion.Drawing
Imports System.ComponentModel
Public Class IconNode
    Inherits DiagramNode
    Shared Sub New()
	  defaultIcon = New Bitmap(50, 50)
	  Dim graphics As Graphics = graphics.FromImage(defaultIcon)
	  Dim font As Font = New Font("Arial", 48, FontStyle.Bold, GraphicsUnit.Pixel)
	  graphics.FillRectangle(Brushes.Transparent, 0, 0, 50, 50)
	  graphics.DrawString("?", font, Brushes.Black, 0, 0)
	  font.Dispose()
	  graphics.Dispose()
    End Sub
    Public Sub New(ByVal diagram As Diagram)
	  MyBase.New(diagram)
	  imgIcon = defaultIcon
	  title = "Test-Titel"
	  format = New StringFormat
	  format.Alignment = StringAlignment.Center
	  format.LineAlignment = StringAlignment.Center
	  Bounds = New RectangleF(Bounds.Location, CalculateSize())
    End Sub
    Public Overrides Sub Draw(ByVal graphics As IGraphics, ByVal options As RenderOptions)
	  Dim iconSizePixels As Rectangle = New Rectangle(0, 0, imgIcon.Width, imgIcon.Height)
	  Dim imageSize As RectangleF = MindFusion.Utilities.DeviceToDoc(graphics, iconSizePixels)
	  ' Draw the icon center at the top
	  graphics.DrawImage(imgIcon, _
	   Bounds.X + Bounds.Width / 2 - imageSize.Width / 2, Bounds.Y)
	  'Draw the label at the bottom
	  Dim labelBounds As RectangleF = RectangleF.FromLTRB( _
	   Bounds.X, Bounds.Y + imageSize.Height, Bounds.Right, Bounds.Bottom)
	  graphics.DrawString(title, _
	   Font, Brushes.Black, labelBounds, format)
    End Sub
    Public Overrides Sub DrawShadow(ByVal graphics As IGraphics, ByVal options As RenderOptions)
    End Sub
    Private Function CalculateSize() As SizeF
	  Dim tempImage As Bitmap = New Bitmap(1, 1)
	  Dim graphics As Graphics = graphics.FromImage(tempImage)
	  Dim measureGraphics As IGraphics = New GdiGraphics(graphics)
	  measureGraphics.PageUnit = Parent.MeasureUnit
	  Dim imageSize As RectangleF = MindFusion.Utilities.DeviceToDoc( _
    measureGraphics, iconSizePixels)
	  measureGraphics.Dispose()
	  tempImage.Dispose()
	  Dim textSize As SizeF = Parent.MeasureString(title, Font, Integer.MaxValue, format)
	  Return New SizeF( _
	   Math.Max(imageSize.Width, textSize.Width), _
	   imageSize.Height + textSize.Height)
    End Function
    Protected Overrides Sub UpdateCreate(ByVal current As PointF)
	  MyBase.UpdateCreate(current)
	  Bounds = New RectangleF(current, CalculateSize())
    End Sub
    Protected Overrides Sub SaveTo(ByVal writer As System.IO.BinaryWriter, ByVal ctx As PersistContext)
	  MyBase.SaveTo(writer, ctx)
	  ' Save the label using the standard .NET BinaryWriter
	  writer.Write(title)
	  'writer.Write(NodeName) macht Probleme beim laden
	  ' Save the image using the FlowChart.NET built-in image saving code,
	  ' which stores the contents of shared images only once.
	  ctx.SaveImage(imgIcon)
    End Sub
    Protected Overrides Sub LoadFrom(ByVal reader As System.IO.BinaryReader, ByVal ctx As PersistContext)
	  MyBase.LoadFrom(reader, ctx)
	  title = reader.ReadString()
	  NodeName = reader.ReadString()
	  'imgIcon = ctx.LoadImage() macht Probleme beim laden
    End Sub
    Public Property Icon() As Image
	  Get
		Return imgIcon
	  End Get
	  Set(ByVal Value As Image)
		imgIcon = Value
	  End Set
    End Property
    Public Property Label() As String
	  Get
		Return title
	  End Get
	  Set(ByVal Value As String)
		title = Value
	  End Set
    End Property
    <CategoryAttribute("Application"), _
Browsable(True), _
[ReadOnly](False), _
BindableAttribute(False), _
DefaultValueAttribute(""), _
DesignOnly(False), _
DescriptionAttribute("Name eingeben")> _
Public Property Name() As String
	  Get
		Return NodeName
	  End Get
		NodeName = Value
	  End Set
    End Property
    Private imgIcon As Image
    Private title As String
    Private NodeName As String
    Private format As StringFormat
    Private Shared defaultIcon As Image
End Class
Reply #10 - Mar 16th, 2009 at 6:26pm
SaveTo writes a string and an image, but LoadFrom tries to read two strings and no image?
