Normal Topic Centre view on a node / box (Read 2197 times)
tronied
Mar 16th, 2009 at 11:53am
Is it possible to centre the FlowChart's view on a node / box? I have tried a couple of things like oFlowChart.setScrollX() and setScrollY() and then using the boxes X and Y values from the bounds (cast to a float), but it never seems to put it in the middle... or even on screen at all sometimes.
Re: Centre view on a node / box
Reply #1 - Mar 16th, 2009 at 12:09pm
The bringIntoView method should center the view on the item, as long as the item is not already visible before calling the method. You might try scrolling to the bottom-right of the diagram to make sure no items are visible, and call bringIntoView after that.
tronied
Reply #2 - Mar 16th, 2009 at 2:59pm
That was  exactly what I was wanting. Thanks
