Hot Topic (More than 10 Replies) controlNode and AnchorPattern (Read 8642 times)
Sachin
Mar 18th, 2009 at 10:58am
HI
I am using Control Node to add my CustomImage in Diagramlite pane,
when i am setting Anchor pattern for this controlNode  throwing Object reference not set to an object
how to avoid this one and get the anchor points
   ControlNode cn = new ControlNode(e.Surface as Diagram, droppedElement);
           AnchorPattern apat1 = new AnchorPattern(new AnchorPoint[]{
new AnchorPoint(50, 0, true, true),
new AnchorPoint(100, 50, true, true),
new AnchorPoint(50, 100, true, true),
new AnchorPoint(0, 50, true, true)
cn.AnchorPattern = apat1 ;
Error ocuured last line
regards
murugan
Re: controlNode and AnchorPattern
Reply #1 - Mar 18th, 2009 at 12:46pm
It's a bug; we've fixed it and this will work in v1.0.2. Though now we might have to delay the release until tomorrow.
Sachin
Reply #2 - Mar 18th, 2009 at 2:19pm
HI
If it is released please send me the link  to get
V1.02  also let me know m how to check whether it is latest or not
Regards
sachin
Reply #3 - Mar 19th, 2009 at 12:00pm
Hi Sachin,
Please try this with the 1.0.2 beta:
https://mindfusion.eu/_beta/DiagramLite102.zip
Sachin
Reply #4 - Mar 19th, 2009 at 12:57pm
HI stoyan
previous version my code  is working fine , new version it is throwing error , how to solve this one
Cannot convert type 'System.Windows.Controls.Panel' to 'MindFusion.Diagramming.Silverlight.Diagram'
regards
murugan
Reply #5 - Mar 19th, 2009 at 1:07pm
Now Diagram derives from Control instead of Canvas. Why do you need to cast it to Panel?
Sachin
Reply #6 - Mar 19th, 2009 at 1:14pm
HI stoyan
i ma using drag and drop functionality images are in silverlight panel ,   i am doing  drag the image and  add dto diagramlite , that is the purpose converting panel to diagramlite , now how to achive this functionality please let me know ..
Reply #7 - Mar 19th, 2009 at 1:32pm
You want to add an Image control directly to the diagram canvas, using Panel.Children.Add? It's not recommended, and is not possible anymore anyway unless we expose the internal canvas as a property of Diagram. Either add a ShapeNode and set its Image property (optionally set Transparent = true to hide the shape), or add a ControlNode that hosts an Image control. In both cases you don't need to cast the Diagram to Panel.
Sachin
Reply #8 - Mar 19th, 2009 at 5:54pm
HI stoyo
if i am using control Node in constructoor need to pass diagram  object ,here only need to convert the panel as diagram object , this is in different layer not in same layer , how to approach here
regards
sachin
Reply #9 - Mar 19th, 2009 at 6:42pm
Hi Sachin,
What exactly is that e.Surface argument? If you are using some third party library that implements drag-and-drop and gives you the UIElement under the mouse, you could use the UIElement.Parent property to get to the Diagram.
Sachin
Reply #10 - Mar 20th, 2009 at 5:08am
In my application I implemented a custom drag and drop functionality. I had written code for moving Node as per mouse movements when user initiates a drag, to implement this I will be moving this Node as is moving across various panels. Ultimately, this Node will be dropped on DiagramLite. Once it is dropped e.Surface will have reference to dropped surface element. It could be any UIElement, but assumption was it will be derived from Panel.  As you had changed Diagram class inheritance itself, to fix earlier bug, it is breaking compatibility. Hope this helps in explaining my requirement.... Any help will be highly appreciable...
thnx.
Reply #11 - Mar 20th, 2009 at 7:06am
We need the diagram to derive from Control because of the keyboard focus management methods that are missing from Panel classes. Now the canvas is set as diagram.Content, and you can access the Diagram using the Parent property. Parent is not defined in UIElement, but in FrameworkElement. That should be ok, since the panel classes are FrameworkElements anyway.
Sachin
Reply #12 - Mar 20th, 2009 at 8:08am
HI
Thanks a lot it is working Smiley
