Normal Topic Animation Support (Read 1773 times)
jaiswalamit
Animation Support
Mar 18th, 2009 at 11:25am
How can I show animation while -
1. Switching from one Layouting to another (I have a dropdown with layout names, on selection change, I create object of the desired Layouting class, and call Arrange() on the diagram object.
2. When I double click a node, I add new nodes (child node to that node and join them using links), so is animation possible here as well?
Please provide any sample code if you have.
Amit
Re: Animation Support
Reply #1 - Mar 18th, 2009 at 12:12pm
Hi Amit,
At this time animation is possible only for iterative layouts such as SpringLayout. You could check the SpringLayout sample from our Windows Forms control:
