Normal Topic Zoom on Diagram View. (Read 3245 times)
SandeepGowda
Mar 18th, 2009 at 1:23pm
hi,
Do we have flexibility of Zoom on Ctrl+Right Mouse Button
regards
sandeep
Re: Zoom on Diagram View.
Reply #1 - Mar 18th, 2009 at 2:55pm
What exactly do you need to do with zoom upon Ctrl+Right Mouse Button?
SandeepGowda
Reply #2 - Mar 18th, 2009 at 3:00pm
Diagram view holding Shape Nodes linked eachother
regards
sandeep
Reply #3 - Mar 18th, 2009 at 3:15pm
Ok, that's what the diagram view usually holds. But what do you need to happen with ZoomFactor when the user clicks Ctrl + Right Mouse Button?
SandeepGowda
Reply #4 - Mar 19th, 2009 at 8:52am
hi,
i am handling the ZOOM on scroll of mouse, can we handle the same using CTrl+Right mouse Key?
* Method Handles the Mouse Scroll on Diagram View.
public void mouseWheelMoved(MouseWheelEvent evt) {
Point2D scrollPos = new Point2D.Float(m_mainDiagramView.getScrollX(),
m_mainDiagramView.getScrollY());
Point scrollPosDev = m_mainDiagramView.docToDevice(scrollPos);
Point mousePosDev = evt.getPoint();
Point2D mouseDocPos = m_mainDiagramView.deviceToDoc(mousePosDev);
Point mouseOffset = new Point(mousePosDev.x + scrollPosDev.x,
mousePosDev.y + scrollPosDev.y);
float oldZoom = m_mainDiagramView.getZoomFactor();
float newZoom = oldZoom + (float) evt.getWheelRotation();
m_mainDiagramView.setZoomFactor(newZoom);
Point2D mouseOffsetDoc = m_mainDiagramView.deviceToDoc(mouseOffset);
float sx = (float) (mouseDocPos.getX() - mouseOffsetDoc.getX());
float sy = (float) (mouseDocPos.getY() - mouseOffsetDoc.getY());
m_mainDiagramView.scrollTo(sx, sy);
regards
sandeep
Reply #5 - Mar 19th, 2009 at 1:13pm
You want to use Ctrl + dragging with right mouse button to zoom? You could do that by handling the Swing's mouseDragged event and instead of adding a factor of the getWheelRotation() value, add a factor of the distance mouse moved from its initial position.
