Normal Topic Right-to-left support (Read 2744 times)
actionbase
Mar 19th, 2009 at 3:09pm
Is there any way to display correctly node text in right-to-left language?
Re: Right-to-left support
Reply #1 - Mar 19th, 2009 at 7:12pm
The node text is displayed using a TextBlock; we'll check if TextBlocks provide some property to set right-to-left direction and expose it as property of the node.
actionbase
Reply #2 - Mar 22nd, 2009 at 2:56pm
Is it possible to use custom control inside node instead of TextBlock? There is an RTL solution (http://www.codeplex.com/SilverlightRTL) on the net and if I could add their TextBlock it will solve the problem.
Reply #3 - Mar 23rd, 2009 at 8:18am
At this time you can host a custom control inside a ControlNode.
