Normal Topic PredShapes sample fail in 1.0.2 (Read 3557 times)
Hai
Mar 23rd, 2009 at 10:19am
Hi
I get the error
Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
in the procedure:
foreach (KeyValuePair<string, Shape> kvp in Shape.Shapes)
Happen in C# and VB
Re: PredShapes sample fail in 1.0.2
Reply #1 - Mar 23rd, 2009 at 12:12pm
Thanks for letting us know of this problem. This build of the beta should fix it:
https://mindfusion.eu/_beta/DiagramLite102.zip
Hai
Reply #2 - Mar 24th, 2009 at 7:50am
Hi Stoyan
I've uninstalled and then installed this version, restarted, but still getting the same error (in the 3rd r 4th run in the loop)
Am i doing something wrong ?
Hai
Reply #3 - Mar 24th, 2009 at 8:42am
Hi Hai,
What's the file date of your diagramlite.dll copy? Since the installer is fairly small, it might have been cached by some proxy server and you got an old copy. Try downloading just the dll from this link:
https://mindfusion.eu/_beta/DiagramLiteDll.zip
Hai
Reply #4 - Mar 24th, 2009 at 9:48am
Yup
that did the trick  Grin
