Normal Topic Zoom not working properly. (Read 1589 times)
Anant_Shukla
Mar 23rd, 2009 at 4:19pm
I do have Zoom-In and Zoom-Out functionality on mouse scroll in my application.
The code used by me is as follows :
ScrollViewer scrollViewer = new ScrollViewer();
e.Handled = true;
Point p = e.GetPosition(Parent as ScrollViewer);
Point oldcurpos = diagram.ClientToDoc(p);
double newScrollX = diagram.ScrollX;
double newScrollY = diagram.ScrollY;
diagram.ZoomFactor += e.Delta / 60;
Rect newBounds = diagram.ClientToDoc(
new Rect(0, 0, scrollViewer.ActualWidth, scrollViewer.ActualHeight));
Point newcurpos = diagram.ClientToDoc(e.GetPosition(Parent as ScrollViewer));
double diffx = (oldcurpos.X - newcurpos.X);
double diffy = (oldcurpos.Y - newcurpos.Y);
newScrollX += diffx;
newScrollY += diffy;
newBounds.X = newScrollX;
newBounds.Y = newScrollY;
newBounds.Union(diagram.GetContentBounds(false, false));
newBounds.Inflate( 200, 200 );
diagram.Bounds = newBounds;
diagram.ScrollTo(new Point(newScrollX, newScrollY));
I want the diagram to always occupy the full containers area both in Zoom-Out and Zoom-In functionality. The code seems to work upto a certain extent of Zoom-Out value then it stops working and diagram start shrinking leaving white spaces.
Also I want the diagram to zoom to fit all the items in the diagram when its initialized. I have used the ZoomToFit method for that but it doesnt seems to work.
Any suggestions what is wrong with the code.
Thanks and Regards,
Anant Shukla.
Re: Zoom not working properly.
Reply #1 - Mar 23rd, 2009 at 6:48pm
Why are you getting the ActualWidth / Heigth of a new ScrollViewer instance instead of the one that contains the diagram? That sample code I sent you simply expects that the ScrollViewer containing the Diagram has a Name attribute set to "scrollViewer"...
