Normal Topic Failed to compare two elements in the array (Read 10147 times)
NiekC
Mar 24th, 2009 at 2:51pm
I often encounter the following exception when selecting or dragging DiagramItems (hard to reproduce exactly). It causes my application to crash. Version:2.1.1.23367
Exception:
System.InvalidOperationException:Failed to compare two elements in the array.
StackTrace:
at System.Array.SorterObjectArray.SwapIfGreaterWithItems(Int32 a, Int32 b)
   at System.Array.SorterObjectArray.QuickSort(Int32 left, Int32 right)
   at System.Array.Sort(Array keys, Array items, Int32 index, Int32 length, IComparer comparer)
   at System.Collections.ArrayList.Sort(Int32 index, Int32 count, IComparer comparer)
   at MindFusion.Diagramming.Wpf.x2965d493a804ca6b.x3ae2538770cbf5a5(Int32 x7f8a886f51b477eb)
   at MindFusion.Diagramming.Wpf.Diagram.x3ae2538770cbf5a5(Int32 x7f8a886f51b477eb)
   at MindFusion.Diagramming.Wpf.Diagram.x3ae2538770cbf5a5()
   at MindFusion.Diagramming.Wpf.Diagram.ArrangeOverride(Size finalSize)
   at System.Windows.FrameworkElement.ArrangeCore(Rect finalRect)
   at System.Windows.UIElement.Arrange(Rect finalRect)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
   at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork()
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
InnerException:
[System.NullReferenceException] = {"Object reference not set to an instance of an object."}
StackTrace:
   at MindFusion.Diagramming.Wpf.Diagram.GetDiagramItem(UIElement item)
   at MindFusion.Diagramming.Wpf.xddab178229d7219f.x7aeaf17dbdd7799a(Object x08db3aeabb253cb1, Object x1e218ceaee1bb583)
   at MindFusion.Diagramming.Wpf.xddab178229d7219f.xd2b26c831a48c764(DiagramItem xde860fba55c41d76, DiagramNode xb6a159a84cb992d6)
   at MindFusion.Diagramming.Wpf.xddab178229d7219f.Compare(Object x, Object y)
Re: Failed to compare two elements in the array
Reply #1 - Mar 24th, 2009 at 4:09pm
What kind of items do you use in your diagram? Could you email a saved xml file to support@mindfusion.eu?
Reply #2 - Mar 24th, 2009 at 4:19pm
Have you by chance added any object not derived from DiagramItem as a child of Diagram or Diagram.DocumentPlane?
Reply #3 - Mar 25th, 2009 at 4:03pm
We could not reproduce that with the diagram you sent us. We don't have any idea how a random Visual object could appear in the diagram and break the comparer code, but added some check to handle this. Please try this version from the PM page and let me know if it still has the problem.
Paul Eden
Reply #4 - Jul 1st, 2009 at 5:24pm
Hi we've just got the message too. We've yet to replicate outside of our application, but thought we'd share the following exception details:
Which was an inner exception of :
the rest of the exception is trunctaed due to forum restrictions.
Did the version sent to the original poster fix the issue?
Paul Eden
NiekC
Reply #5 - Jul 2nd, 2009 at 8:08am
Yes, after being send a few tryouts, my problem was quickly solved.  Grin
Reply #6 - Jul 2nd, 2009 at 8:14am
Hi Paul,
Try the version from the PM page.
Paul Eden
Reply #7 - Jul 9th, 2009 at 12:31pm
Thanks - looks like tht has fixed the issue for us.
What development state is this DLL in - should it be considered beta and if so when will the live version have this fix?
Many thanks
Paul
Reply #8 - Jul 9th, 2009 at 2:45pm
It should be stable, it's close to the build we are releasing now with v2.2.
