Normal Topic diagram Autoresize option (Read 834 times)
rishiupendran
Mar 26th, 2009 at 7:56am
we are trying to restrict the resize option to user.
we have used the following property.
Diagram.AutoResize= None. But this is not working.
What could be the problem??
rgds,
Rishi
Re: diagram Autoresize option
Reply #1 - Mar 26th, 2009 at 10:15am
This property is saved in XML files, so if you call LoadFromXml, it might get enabled again. Perhaps you could set Diagram.AutoResize= None after LoadFromXml.
