Normal Topic Few issues. (Read 2753 times)
Shane
Few issues.
Mar 26th, 2009 at 10:23am
Hi All,
I am trying to highlight the active node when the HandleStyle property of the node is set to MoveOnly.
I referred   to the following discussion from the forum. The suggestion is as follows :
" You could set the Brush to highlight the node, or set HandlesStyle = Custom and draw the selection frame as you need it from the DrawAdjustmentHandles event handler. "
But the problem is I cannot use the first suggestion related to setting the brush of active node. Can someone please provide few details how to incorporate the second suggestion.
Shane.
Re: Few issues.
Reply #1 - Mar 26th, 2009 at 2:29pm
Hi Shane,
This example shows how to implement custom drawing for selection handles:
https://mindfusion.eu/_samples/CustomHandlesStyle.zip
Shane
Re: Few issues.
Reply #2 - Mar 27th, 2009 at 12:16pm
Hi Stoyan,
That reference has provided a lot of help and the functionality is running fine.
I also have a functionality to lock the movement of the node on click of a button the code used by me for the purpose is as follows :
void diagram_NodeStartModifying(object sender, NodeValidationEventArgs e)
           if (lockNodeMovement)
               e.CancelDrag();
               diagram.OverrideCursor = Cursors.Arrow;
           else
               diagram.OverrideCursor = null;
By integerating the code the node movement is distorted i.e when nodes are selected and user tend to move them by dragging the mouse then nodes mutual alignment get distorted.
I have set the HandleStyle property of the nodes as custom.
Any suggestions how can I fix this.
Shane.
Re: Few issues.
Reply #3 - Mar 27th, 2009 at 1:48pm
Hi Shane,
Have you tried setting node.Locked = true?
Shane
Re: Few issues.
Reply #4 - Mar 27th, 2009 at 2:13pm
Hi Stoyan,
Yes I have already tried that approach but its not working thats why I used the method from my last post.
Can you suggest another approach.
I am also using this method in my code.
     void diagram_SelectionMoving(object sender, ValidationEventArgs e)
               e.CancelDrag();
           else
Shane.
Re: Few issues.
Reply #5 - Mar 29th, 2009 at 9:38am
Hi Shane,
Are you trying to lock the movement of all items in the diagram? You could do that by setting Behavior = DoNothing. Otherwise you might have to handle both NodeModifying and SelectionMoving to cancel the movement.
