Normal Topic Restrict Links to Bounds (Read 977 times)
rzanni
Mar 26th, 2009 at 4:56pm
I'm using RestrictItemsToBounds property for Nodes and it works great, but I'm having problems with the links going outside the document area.
How can I also restrict links to document bounds (inside only)
Thanks.
Re: Restrict Links to Bounds
Reply #1 - Mar 27th, 2009 at 7:39am
Are you using auto-routed links? Seems sometimes their segments are placed exactly at the diagram boundaries. You could handle LinkRouted and move the points back a bit if you detect that X or Y for some point is <= diagram.Bounds.X/Y, or add a transparent obstacle node along each side of the diagram to repulse the links.
