Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) Moving shadow not the actual item (Read 15378 times)
Re: Moving shadow not the actual item
Reply #30 - Nov 20th, 2009 at 11:14am
Hi Anshul,
AutoHandles works both for nodes and links. If you need the handles to be drawn only if the link is selected, you could set the HandlesStyle to Custom and in the DrawAdjustmentHandles handler draw the link handles only in that case.
Anshul
Senior Member
Reply #31 - Nov 21st, 2009 at 8:57am
Hi Stoyan,
I have set link style to custom at the time of creation and in DrawAdjustmentHandles handler I am changing its style to SquareHandle. It is working fine for first time but once it passes through the DrawAdjustmentHandles handler link style gets changed to SquareHandle.
My question is where I can reset link's style to custom?
The code which I have written inside DrawAdjustmentHandles  is given below.
if (e.Item is DiagramLink && e.Item.Selected)
				DiagramLink link = e.Item as DiagramLink;
				link.HandlesStyle = HandlesStyle.SquareHandles;
Anshul
Anshul
Senior Member
Reply #32 - Nov 23rd, 2009 at 6:55am
Hi Stoyan,
Any suggestion for this?
Anshul
Reply #33 - Nov 23rd, 2009 at 7:49am
I suppose you are setting HandlesStyle = SquareHandles in order to make the link's DrawHandles method render the handles. So after calling e.Link.DrawHandles(), set link.HandlesStyle = Custom again.
Alternatively, you could simply loop over the link's ControlPoints and draw some rectangles around them:
void diagram_DrawAdjustmentHandles(object sender, DrawItemEventArgs e)
	var link = e.Item as DiagramLink;
	if (link != null && link.Selected)
		foreach (Point p in link.ControlPoints)
			DrawRect(e.Graphics, p, diagram.AdjustmentHandlesSize);
private void DrawRect(DrawingContext dc, Point center, double size)
	dc.DrawRectangle(Brushes.White, new Pen(Brushes.Black, 1), new Rect(
		center.X - size / 2, center.Y - size / 2, size, size));
Anshul
Senior Member
Reply #34 - Nov 23rd, 2009 at 8:14am
Thanks Stoyan Smiley
Anshul
Senior Member
Reply #35 - Dec 3rd, 2009 at 5:26am
Hi Stoyan,
Try the Diagram.CancelDrag method from this version:
https://www.mindfusion.eu/_beta/wpfdiag_canceldrag.zip
I want to know, to fix this issue when we can get next licensed build of MindFusion.Diagramming.Wpf ?
Anshul
Reply #36 - Dec 3rd, 2009 at 8:54am
In January.
