Hot Topic (More than 10 Replies) Custom Saving (Read 6525 times)
Sachin
Custom Saving
Mar 30th, 2009 at 11:05am
HI
in my application created  custom no de  and saved in string
while calling load string method throwing Value cannot be null error
Re: Custom Saving
Reply #1 - Mar 30th, 2009 at 12:52pm
Are your custom nodes controls hosted in ControlNodes, or they are DiagramNode-derived types?
Sachin
Re: Custom Saving
Reply #2 - Mar 31st, 2009 at 5:22am
HI
Yes i am using controlNodes to host my control
then saving ,
How to load the string
Re: Custom Saving
Reply #3 - Mar 31st, 2009 at 10:18am
The properties of your hosted controls are not saved and loaded automatically, you must handle the Serialize/DeserializeControl events to do that. You might get an exception if you don't handle the events and the custom controls expects some of its values to be != null.
Sachin
Re: Custom Saving
Reply #4 - Mar 31st, 2009 at 12:54pm
In Serializae and deserialize event what i have to write can u give one example
Re: Custom Saving
Reply #5 - Mar 31st, 2009 at 3:04pm
Check the SerializeControl help topic.
Sachin
Re: Custom Saving
Reply #6 - Apr 1st, 2009 at 6:52am
HI
In my serialization event  below code i written
DragDropControl is a custom control  this comtrol converted and  hosting to controlNode
DragAndDropControl control = e.Node.Control as DragAndDropControl ;
           e.Handled = true;
           e.Context.WriteXaml(control, "DragDrop", e.XmlElement);
in save click saving the diagram ,
private void save_Click(object sender, RoutedEventArgs e)
          s =   this.DiagramLight.SaveToString(SaveToStringFormat. Base64);
          this.DiagramLight.ClearAll();
here i am provided another button to retive the diagram so how to deserialize and retrive the diagram
Re: Custom Saving
Reply #7 - Apr 1st, 2009 at 8:45am
WriteXaml remains from the WPF version of the control, but seems we haven't implemented it because there is no XamlWriter available in Silverlight. You'll have to serialize your properties using the Linq for XML API, or using methods such as e.Context.WriteString to save individual properties.
Sachin
Re: Custom Saving
Reply #8 - Apr 1st, 2009 at 9:23am
hi
really i am not getting , can u  able to write  the code for serialize and deserialize for this problem,
Re: Custom Saving
Reply #9 - Apr 1st, 2009 at 2:51pm
Suppose your control looks like this:
<UserControl x:Class="TestApp.CustomControl"
	xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
	xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
	Width="50" Height="50">
	<Grid x:Name="LayoutRoot" Background="BurlyWood">
		<ComboBox Name="cmBox" Visibility="Visible"
			HorizontalAlignment="Center" VerticalAlignment="Top" Margin="0,0,0,0" Width="50" Height="30">
			<ComboBoxItem IsSelected="True" Content="1"></ComboBoxItem>
			<ComboBoxItem Content="2"></ComboBoxItem>
			<ComboBoxItem Content="3"></ComboBoxItem>
		</ComboBox>
		<TextBox Margin="0,0,0,0" Name="txBx" HorizontalAlignment="Stretch" VerticalAlignment="Bottom"
			Height="20" Padding="0" TextWrapping="Wrap">
		</TextBox>
	</Grid>
</UserControl>
You could save and load its properties like this:
private void Diagram_SerializeControl(object sender, MindFusion.Diagramming.Silverlight.ControlNodeEventArgs e)
	e.Handled = true;
	e.Context.WriteBrush((e.Node.Control as CustomControl).Background, "Brush", e.XmlElement);
	e.Context.WriteInt((e.Node.Control as CustomControl).SelectedIndex, "SelectedIndex", e.XmlElement);
	e.Context.WriteString((e.Node.Control as CustomControl).Text, "Text", e.XmlElement);
private void Diagram_DeserializeControl(object sender, MindFusion.Diagramming.Silverlight.ControlNodeEventArgs e)
	e.Handled = true;
	XElement controlElement = e.XmlElement;
	Brush brush = e.Context.ReadBrush("Brush", controlElement);
	int index = e.Context.ReadInt("SelectedIndex", controlElement);
	string text = e.Context.ReadString("Text", controlElement);
	CustomControl control = new CustomControl();
	//control.ParentNode = e.Node;
	control.Text = text;
	control.SelectedIndex = index;
	control.Background = brush;
	e.Node.Control = control;
If you are using more than one type of custom controls, you could save their type name, say as an attribute of the parent XElement given as an argument to those events.
Sachin
Re: Custom Saving
Reply #10 - Apr 14th, 2009 at 1:17pm
HI Stoyo
in my application is complex one so many diagrams will come , saving is very difficult what u said last post , also retriving also  need to  implement  this functionality  another one is need to save in database second time it should come from database . very urgent requirement ,
curently we are implemented WIndows application using Go diagram Tool  it is support lot of features,
same thing need to except from diagram light discussion going on to buy diagramlight so please try to implement as most of the functionality , if u have any clarification we will chat directly
thank you
Sachin
