Normal Topic Shape link (Read 4850 times)
maor
Shape link
Mar 31st, 2009 at 3:05pm
Can i define a link to shape, that when i click on the shape its open the link inside
(for example : http://mindfusion.eu)
Re: Shape link
Reply #1 - Mar 31st, 2009 at 3:09pm
You could navigate to the link from the NodeClicked event handler.
maor
Re: Shape link
Reply #2 - Mar 31st, 2009 at 3:14pm
Ok..
I knew this way..
But i want to know if there is way to set the shape to link.(blue text with underline).
Re: Shape link
Reply #3 - Apr 1st, 2009 at 8:36am
It's not possible unless you create a custom node type or use a control hosted in ControlNode. We'll have to expose some properties of the TextBlock used to display text to enable this for ShapeNodes.
maor
Re: Shape link
Reply #4 - Apr 1st, 2009 at 9:01am
Can you send me an example?
Re: Shape link
Reply #5 - Apr 1st, 2009 at 1:23pm
in xaml:
<UserControl x:Class="DiagramLiteTest.HyperlinkControl"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    Width="400" Height="300">
	<Grid x:Name="LayoutRoot" Background="White">
		<TextBlock Name="textBlock" TextDecorations="Underline"
			Foreground="Blue" HorizontalAlignment="Center" VerticalAlignment="Center"></TextBlock>
	</Grid>
</UserControl>
in the codebehind:
public partial class HyperlinkControl : UserControl
	public HyperlinkControl()
		InitializeComponent();
	public string Url
		get { return textBlock.Text; }
		set { textBlock.Text = value; }
and then you can add hyperlink nodes to the diagram as below:
HyperlinkControl hlink = new HyperlinkControl();
hlink.Url = "www.google.com";
ControlNode hnode = new ControlNode(diagram, hlink);
diagram.Nodes.Add(hnode);
hnode.Bounds = new Rect(0, 0, 100, 100);
maor
Re: Shape link
Reply #6 - Apr 1st, 2009 at 1:26pm
Its look good.. thanks
so i need to create the class HyperlinkControl : UserControl?
thanks.
Re: Shape link
Reply #7 - Apr 1st, 2009 at 1:28pm
Yep, or wait for us to add some ShapeNode property to let you set TextDecorations of the internal textblock.
