Normal Topic Problem with select link (Read 4441 times)
tzippy
Apr 2nd, 2009 at 3:29pm
I have a problem with the selection of the link.
I click on the diagram (not on a node or a link),
and the click set one link to be selected.
Re: Problem with select link
Reply #1 - Apr 2nd, 2009 at 5:24pm
That's by design, to make link selection easier. There is few millimeters area around links that is considered a hit on the link when clicked.
tzippy
Reply #2 - Apr 5th, 2009 at 8:16am
But, It is more then a few millimeters. It is seem as an one centimeter . Should I control this value and change it to a smaller value?
Reply #3 - Apr 6th, 2009 at 9:26am
We'll add some property to let you control that distance.
tzippy
Reply #4 - Apr 16th, 2009 at 10:39am
Thanks.
When will you do that?
Reply #5 - Apr 17th, 2009 at 9:03am
Soon.
tzippy
Reply #6 - May 10th, 2009 at 6:43am
What about it?
I'm still waiting...
Reply #7 - May 11th, 2009 at 12:00pm
https://mindfusion.eu/_beta/wpfdiag_hitdist.zip
adds the LinkHitDistance property, documented here (for the WinForms version).
tzippy
Reply #8 - May 31st, 2009 at 3:17pm
Can you explain me please how to use LinkHitDistance property?
I tried the value 0, but it doesn't work well.
Reply #9 - Jun 1st, 2009 at 4:52am
0 is the default and works as before, each click in the few millimeters area around the link is considered a hit. Assign a value different than 0 to make the control use your value, e.g. you could set it to 0.1.
