Hot Topic (More than 10 Replies) Routed links all messed up… (Read 7834 times)
Hai
Apr 2nd, 2009 at 5:20pm
Hi
In my workflow diagram I'm preventing the user from free drawing on the diagram surface.
The workflow XAML looks like that:
<my:Diagram x:Name="wfDiagram" ModificationStart="SelectedOnly" Bounds="0, 0, 2000, 2000" VerticalAlignment="Stretch" ShapeBrush="White"
HorizontalAlignment="Stretch"
AllowInplaceEdit="False" LinkBrush="Green" RouteLinks="True"
LinkSelected="wfDiagram_LinkSelected" LinkDeselected="wfDiagram_LinkDeselected" LinkCreated="wfDiagram_LinkCreated" LinkModified="wfDiagram_LinkModified"
NodeSelected="wfDiagram_NodeSelected" NodeDeselected="wfDiagram_NodeDeselected"
MouseLeftButtonDown="wfDiagram_MouseLeftButtonDown" MouseMove="wfDiagram_MouseMove">
</my:Diagram>
And in the C# I initialize with
////Disable multy select
wfDiagram.Selection.AllowMultipleSelection = false;
wfDiagram.CustomBehavior = new clsNodeCustomBehavior(wfDiagram);
wfDiagram.Behavior = Behavior.Custom;
//Make The routing link better
wfDiagram.RoutingOptions.GridSize = 2;
wfDiagram.RoutingOptions.StartOrientation = MindFusion.Diagramming.Silverlight.Orientation.Horizontal;
wfDiagram.RoutingOptions.EndOrientation = MindFusion.Diagramming.Silverlight.Orientation.Auto;
wfDiagram.RoutingOptions.Anchoring = Anchoring.Keep;
Where clsNodeCustomBehavior Is
public class clsNodeCustomBehavior :BehaviorBase
public clsNodeCustomBehavior(Diagram diagram)
: base(diagram)
public override InteractionState StartDraw(Point point)
DiagramNode node = Diagram.GetNodeAt(point);
if (node != null)
return new InteractionState(node, MindFusion.Diagramming.Silverlight.Action.Modify, 8, point);
return null;
Now, when the user adds a few nodes with routing links and then perform the following action:
1. MouseDown on the diagram in an empty place (no nodes or links).
2. Quick drag, while the mouse button is down through some routed links
What happened is that the routed links get all messed up ???
Any Idea why that happen and is there a fix for that ?
Hope I was clear enough
Many thanks
Hai
Re: Routed links all messed up…
Reply #1 - Apr 2nd, 2009 at 5:30pm
What exactly happens in the mouse event handlers attached to the diagram?
Hai
Reply #2 - Apr 2nd, 2009 at 5:36pm
Not much....
If I'm in "drag the entire workflow" mode than I manipulate th cursor
       private void wfDiagram_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
           if (_bDraggingWorkspace == true)
               Cursor = Cursors.Hand;
               wfDiagram.Cursor = Cursors.Hand;
           else
               //wfDiagram.Behavior = Behavior.DoNothing;
       private void wfDiagram_MouseMove(object sender, MouseEventArgs e)
But in the scenario that I've pointed _bDraggingWorkspace = false... so nothing actually
Thx
Hai
Reply #3 - Apr 2nd, 2009 at 5:40pm
Are you sure you are not selecting and moving some links inadvertently? Could you email a small project that reproduces this to our support email address?
Hai
Reply #4 - Apr 2nd, 2009 at 5:48pm
I wish I could, but not at the moment... Our project is Huge... Cheesy
I may be able to do It on sunday... I just though that maybe you can think of something that I do that could create this kind of behavior....
I'm not moving a link or a node... I click on an "Empty" area of the diagram.
It's a bit similar to if I was painting a shape through the routed links so they would have reposition themselves but this is not the case because I do not paint nothing....
Just hoped that you will have something in mind...
(Stoyan is quite farmiliar with what I did with your control along the way... if you are not him, maybe you can consult Roll Eyes )
Reply #5 - Apr 3rd, 2009 at 7:26am
What happens in the Deselected handlers?
Hai
Reply #6 - Apr 5th, 2009 at 6:59am
I have a property panel that I show hide and update.
       private void wfDiagram_NodeDeselected(object sender, NodeEventArgs e)
           HideProperties();
       private void wfDiagram_LinkDeselected(object sender, LinkEventArgs e)
           _dlnkCur_Sel_Link = null;
           //Clear Properties
           panelProperties.Children.Clear();
       private void HideProperties()
           _dnodeCur_Sel_Node = null;
           //Clear
           grdShoHideProperties.Visibility = Visibility.Collapsed;
Any idea what can cause my srange behaviour ?
Reply #7 - Apr 6th, 2009 at 9:43am
Not any. Please email us a project that shows that if you can.
Hai
Reply #8 - Apr 6th, 2009 at 9:45am
Well... thanks for the effort...
I'll do my best to do it soon  Smiley
Hai
Reply #9 - Apr 7th, 2009 at 4:52pm
Hust sent a test project to
support@mindfusion.eu
8)
Thx
hai
Reply #10 - Apr 8th, 2009 at 8:01am
Our developer will check it today.
Reply #11 - Apr 8th, 2009 at 9:01am
The problem is that your Links button sets wfDiagram.Behavior = Behavior.LinkControls. This means that when users start drawing from a node, there is a link created, otherwise there is a ControlNode created. So when you draw from one corner of the diagram to another, there is a big ControlNode created that triggers rerouting all links, but the path-finding fails since that node is an obstacle.
Note that the ControlNode even contains a Rectangle control, which is set as DefaultControlType, however the rectangle does not have any style attributes set so it's a bit invisible Wink
One way to handle this is to handle NodeCreating and call e.CancelDrag while in draw links mode. Another way is to create a second custom behavior to use for the draw-links mode, that never creates a node.
« Last Edit: Apr 8th, 2009 at 11:30am by Stoyo »
Hai
Reply #12 - Apr 13th, 2009 at 7:35am
I've used the second one...
Yooooppppeeeee... it works
Grin
Thx
Hai
