Normal Topic How to move selected nodes by using ArrowKey (Read 3260 times)
Anshul
Senior Member
Apr 3rd, 2009 at 7:01am
Hi i am new to WPF.have anybody idea about this ?
Re: How to move selected nodes by using ArrowKey
Reply #1 - Apr 3rd, 2009 at 8:22am
The arrow keys have some default bindings to change the selection. You can override them to move nodes as shown below:
diagram.CommandBindings.Add(
	new CommandBinding(Diagram.NavigateLeft, (sender, args) =>
		DiagramNode node = diagram.ActiveItem as DiagramNode;
		if (node != null)
			node.Move(node.Bounds.Left - 10, node.Bounds.Top);
Anshul
Senior Member
Reply #2 - Apr 3rd, 2009 at 9:02am
Hi Stoyan,
i have written this code in the constructor,but its not working.am i missing something?
Anshul
Anshul
Senior Member
Reply #3 - Apr 3rd, 2009 at 12:12pm
Hi Stoyan,
This code is working fine only when i select any item and set focus on the diagram, but if i dont focus on the diagram,its not work.
what i want is that,i simply want to select any item than by using arrow key,move any item without focusing on the diagram.
Anshul
Reply #4 - Apr 3rd, 2009 at 1:38pm
Try adding a KeyDown handler to the root window.
