Normal Topic Method for reassigning links to nearest anchor points? (Read 2990 times)
beetee
Jul 13th, 2017 at 9:15am
Is there any method available that reassigns links to nearest anchor points? I know that DiagramNode.ReassignAnchorPoints method evenly distributes the links to anchor points.
Kindly refer the attached document for more details.
BT
ReassignAnchorPoints_according_to_nearest_points.docx (Attachment deleted)
Re: Method for reassigning links to nearest anchor points?
Reply #1 - Jul 13th, 2017 at 10:47am
Have you tried calling link.ReassignAnchorPoints()?
beetee
Reply #2 - Jul 13th, 2017 at 1:03pm
Hello Slavcho,
I have tried link.ReassignAnchorPoints() and could not get expected behavior. I think this method will reassign anchor points on both sides of the link.
Looking for some API like node.ReassignAnchorPoints() which reassign anchor points only according to the nearest point and does not try to evenly distribute the anchor points.
Thank you
BT
Reply #3 - Jul 13th, 2017 at 4:43pm
Hi BT,
Try this method -
Point PositionInDiagram(AnchorPoint ap, DiagramNode node)
	var r = node.Bounds;
	return new Point(
		r.X + r.Width * ap.X / 100,
		r.Y + r.Height * ap.Y / 100);
int NearestAnchorPoint(DiagramNode node, bool incoming, Point point)
	int nearest = -1;
	double minDist = Double.MaxValue;
	for (int i = 0; i < node.AnchorPattern.Points.Count; i++)
		var ap = node.AnchorPattern.Points[i];
		if (ap.AllowIncoming != incoming)
			continue;
		var pos = PositionInDiagram(ap, node);
		var dist = Utilities.Distance(pos, point);
		if (dist < minDist)
			minDist = dist;
			nearest = i;
	return nearest;
void AlignEndToAnchorPoint(DiagramLink link)
	var destNode = link.Destination;
	var destAnchor = NearestAnchorPoint(
		destNode, true, link.StartPoint);
	if (destAnchor > -1)
		link.EndPoint = PositionInDiagram(
			destNode.AnchorPattern.Points[destAnchor],
			destNode);
		link.DestinationAnchor = destAnchor;
		link.Route();
beetee
Reply #4 - Jul 14th, 2017 at 8:52am
Hello Slavcho,
It works with your code.
Thank you very much.
BT
