Normal Topic select but no modify (Read 1140 times)
Bjorn
Alfadata Technologies
Corporation
Apr 3rd, 2009 at 9:14pm
I am trying to disable modification and moving of links and nodes (while maintaining the ability to select them).
I have been able to individually disable several things (moving links and nodes by cancelling linkstartmodified event, reanchoring through the LinkEndsMovable, but I can't find a way to prevent the user from being able to create control points.  For some reason, this doesn't fire the linkstartmodified event.
Is there a way to disable the creation of control points, or is there an easier way to make objects selectable but not able to be modified?  I prefer to do this on a global scale, but I can do it on every object individually as well if neccessary.
Thanks in advance for any assistance!
Re: select but no modify
Reply #1 - Apr 6th, 2009 at 8:40am
You could set Behavior = DoNothing, and select items in response to the NodeClicked and LinkClicked event by calling diagram.Selection.Change(). Otherwise, preventing the user from creating control points can be done by setting AllowSplitLinks = false.
