Normal Topic Custom self linking (Read 1201 times)
SavyCat
Custom self linking
Apr 7th, 2009 at 2:20pm
Hi guys, I've come accross something that might be a future request, as I dont think its currently possible.
Basically, I have a node with a number of inputs and outputs. The node is a square, and all input anchors are on the left and the output ones are on the right. I want the option to be available for the user to link of the outputs back onto one of the inputs of the node. Currently, if I do that and AllowSelfLoops is true, it automatically makes the link a bezier, originating from the top centre opf the node. If I turn AllowSelfLoops  off, the link remains bezier, is still positioned on the top centre but its destination anchor is correct.
Basically I need it so that the link acts like the other links and leaves its origin anchor point - keeps its current style and connect back to the node at the entry anchor.
Mat
Re: Custom self linking
Reply #1 - Apr 7th, 2009 at 2:36pm
Try this:
private void diagram_LinkCreated(object sender, LinkEventArgs e)
	if (e.Link.Origin == e.Link.Destination)
		SetSelfLoopShape(e.Link);
private void SetSelfLoopShape(DiagramLink link)
	link.SegmentCount = 3;
	link.Style = LinkStyle.Cascading;
	diagram.RoutingOptions.Anchoring = Anchoring.Reassign;
	link.Route();
SavyCat
Reply #2 - Apr 7th, 2009 at 3:34pm
I managed to get a good effect by doing this:
/// <summary>
        /// This function is used for setting up self looped links
        /// </summary>
        /// <param name="link"></param>
            int oAnchor = link.OriginAnchor;
            int dAnchor = link.DestinationAnchor;
            link.OriginAnchor = -1;
            link.DestinationAnchor = -1;
            link.OriginAnchor = oAnchor;
            link.DestinationAnchor = dAnchor;
            AnchorPoint oAnchorPointO = link.Origin.AnchorPattern.Points[link.OriginIndex];
            float anchorOriginPosX = link.Origin.Bounds.Width * (oAnchorPointO.X / 100.0f) + link.Origin.Bounds.X;
            float anchorOriginPosY = link.Origin.Bounds.Height * (oAnchorPointO.Y / 100.0f) + link.Origin.Bounds.Y;
            AnchorPoint oAnchorPointD = link.Destination.AnchorPattern.Points[link.DestinationIndex];
            float anchorDestinationPosX = link.Destination.Bounds.Width * (oAnchorPointD.X / 100.0f) + link.Destination.Bounds.X;
            float anchorDestinationPosY = link.Destination.Bounds.Height * (oAnchorPointD.Y / 100.0f) + link.Destination.Bounds.Y;
            link.ControlPoints.Clear();
            link.ControlPoints.Add(new PointF(anchorOriginPosX, anchorOriginPosY));
            link.ControlPoints.Add(new PointF(anchorOriginPosX + 3, anchorOriginPosY));
            link.ControlPoints.Add(new PointF(anchorOriginPosX + 3, anchorOriginPosY - link.Destination.Bounds.Height));
            link.ControlPoints.Add(new PointF(anchorDestinationPosX - 3, anchorOriginPosY - link.Destination.Bounds.Height));
            link.ControlPoints.Add(new PointF(anchorDestinationPosX - 3, anchorDestinationPosY));
            link.ControlPoints.Add(new PointF(anchorDestinationPosX, anchorDestinationPosY));
            link.RetainForm = true;
