Normal Topic Diagram.LinkModified (Read 1869 times)
Benoit Caron
Apr 8th, 2009 at 9:06pm
Hello everyone,
Hi have the following property values in my diagram
  • Diagram.AllowUnanchoredLinks = false
    Diagram.AllowUnconnectedLinks = false
When moving a selected node in the diagram, every links connected to it is changed to follow the node.  However, neither of the following events are raised: Diagram.LinkModifying and Diagram.LinkModified.  Is this the correct behaviour?
If the link is also selected, Diagram.LinkModified is raised but Diagram.LinkModifying is not.  Is that also the correct behaqviour?
I was expecting these events to be raised as soon as the link changes, by direct manipulation or as a side effect.
thanks,
Benoît Caron
Re: Diagram.LinkModified
Reply #1 - Apr 9th, 2009 at 7:53am
LinkModifying is a validation event and designed mostly to let you prevent the user from connecting a link to some nodes. Raising it while a node is being modified brings a similar question as in your other post - what should happen if you set e.Cancel or call e.CancelDrag() fore some link while a node is being modified.
Benoit Caron
Reply #2 - Apr 9th, 2009 at 1:47pm
I understand.
What I want to do is to update the bezier control points of the link to keep a nice curve has I'm moving the node.  I was looking for an event on the link.
I ended up relying on NodeModifying and SelectionMoving but I have to look for every possible connection on every anchor to do it.
Any suggestion?
thanks,
Benoît
Reply #3 - Apr 9th, 2009 at 2:19pm
You will have to do something similar:
void MakeNiceCurve(DiagramLink link)
void OnLinkModified(...)
	MakeNiceCurve(e.Link);
void OnNodeModified(...)
	DiagramLinkCollection links = e.Node.GetAllLinks();
	foreach (DiagramLink link in links)
void OnSelectionMoved(...)
	// loop over Selection.Nodes and Selection.Links and process them as above
Benoit Caron
Reply #4 - Apr 9th, 2009 at 3:13pm
yep, this is exactly what I ended up doing Smiley
thanks
