Normal Topic Diagram.NodeModifying vs Diagram.SelectionMoving (Read 1448 times)
Benoit Caron
Apr 8th, 2009 at 9:14pm
Hello everyone,
If I select one node in my diagram and move it, the event Diagram.NodeModifying is raised and the event Diagram.SelectionMoving i is not.
If I select two nodes, it is the opposite.
Why are they releated?  I was expecting both events to be raised regardless of how many nodes are selected.
Is this the expected behaviour?
thanks,
Benoît Caron
Re: Diagram.NodeModifying vs Diagram.SelectionMovi
Reply #1 - Apr 9th, 2009 at 7:46am
Well, yes, the control makes distinction between moving or resizing a single node and moving a multiple selection of nodes. In the latter case it is always a move operation, while the former could be rotation or resize operation as well. Also it would complicate event handling a bit, e.g. what should happen if you set e.Cancel or call e.CancelDrag() from the NodeModifying handler raised for some node in a multiple selection?
Benoit Caron
Reply #2 - Apr 9th, 2009 at 1:41pm
Good point.  Thanks for the info.
Benoît Caron
