Normal Topic ZIndex sorting. Links always behind nodes. (Read 2330 times)
areddan
Apr 9th, 2009 at 1:49am
I'm trying to implement some behaviour such that links will always be behind nodes.
As a test, I've used the following code whenever a DiagramItem is selected:
  if (a_item->GetType() == MindFusion::Diagramming::DiagramNode::typeid || a_item->GetType()->IsSubclassOf(MindFusion::Diagramming::DiagramNode::typeid))
    a_item->ZTop();
  else
    a_item->ZIndex = Diagram->Nodes->Count - 1;
By selecting a node, this works sure enough - but then when I select a link, it appears above the node which was just brought to the top. I checked the ZIndex after selecting the node and then after selecting the link and the node is higher - The only think I can think of is that it gets set lower in code beyond my control once the link is selected.
I have SelectionAlwaysOnTop set to false.
Re: ZIndex sorting. Links always behind nodes.
Reply #1 - Apr 9th, 2009 at 7:38am
This worked in my test:
private void button2_Click(object sender, EventArgs e)
	diagram.SelectionOnTop = false;
	foreach (DiagramNode node in diagram.Nodes)
		node.ZTop();
Changing the Z order might not be possible in some contexts; in response to what event does your code run?
luffy911
Reply #2 - Sep 13th, 2010 at 9:52pm
I have a similar system in my application. I am using ZBottom to make sure some ui elements are below everything else. It works but it is slow. Are there any other way to do this ?
I am currently experimenting with the removal of all nodes and adding them in the right order but the problem with this is when a node is remove from the diagram, it detaches itself... I am looking into re attaching it after the sorting.
Thank you
Reply #3 - Sep 14th, 2010 at 5:41am
You could directly reorder the elements of Diagram.Items to set the Z order quickly. However each item keeps its own index within that collection in a private field, and unfortunately there is no public method to get these indices in sync with the new Items order. We can add such method for the next release, and for now you could try some workarounds. E.g. after reordering Diagram.Items, execute an empty CompositeCmd created using the constructor that takes a 'saveZOrder' argument, and then immediately undo it. That should update the items Z indices according to the Items order. Another possibility is to call ZTop followed by ZBottom for the first item to update the Z indices for all other items.
luffy911
Reply #4 - Sep 14th, 2010 at 6:57pm
Thank you Stoyo It works great.
I did this:
// needed since diagram.Items has no sort functions
ArrayList.Adapter((IList)diagram.Items).Sort(comp);
// Force the update of all ZIndex of the items
if( diagramItems.Count > 0)
     var item = diagram.Items[0];
     item.ZTop();
     item.ZBottom();
