Normal Topic Disable Selecting of Nodes/Links (Read 1561 times)
Nedor
Sep 15th, 2010 at 9:06am
Is there any way to disable the selection of nodes/link and disable the edit funktion during the Behavior.DrawXXX (XXX=ShapeNodes,Links ... ) functions?
I want only Draw (and Add) new Nodes/Links to the diagram.
I change the Behavior to Behavior.Modify if i want to select (and modify) the nodes.
Re: Disable Selecting of Nodes/Links
Reply #1 - Sep 15th, 2010 at 10:04am
Handle the NodeSelecting and LinkSelecting validation events, and set e.Cancel = true.
Nedor
Reply #2 - Sep 15th, 2010 at 11:41am
Thanks, this works well, now i have another question:
If I change the behavior, all selected Items are deselected. But I want to "take" this selection in the new Behavior. Do I have to store the current selection, change the behavior and reset the selection? Or are there some other functions which are allowing to change the behavior without deselecting all Items?
Reply #3 - Sep 15th, 2010 at 6:19pm
Clearing the selection from the Behavior setter doesn't seem to make much sense, perhaps it's some remnant from our ActiveX control where it was necessary for some reason. Now this build won't clear it anymore:
https://mindfusion.eu/_beta/fcnet541.zip
