Normal Topic Animated Gif is not working with shapenode (Read 1926 times)
muthuhamid
Apr 29th, 2009 at 5:43am
Hi
I am having some shape node with some Image on it, after some process i need to change the static image to some Animated gif image.
Changing Image is working fine but the animation is not working with that image in that shape node.
Can you please tell me how to fix this problem?
Thanks & Regards
Hamid
Re: Animated Gif is not working with shapenode
Reply #1 - Apr 29th, 2009 at 8:33am
There is no built-in support for animated gifs. You could change the Image property from a timer event if you need animation.
muthuhamid
Reply #2 - May 5th, 2009 at 6:36am
Thanks Stoyo, As you said i have done with Timer and it works really great...
Thanks again
Hamid
muthuhamid
Reply #3 - Sep 19th, 2010 at 4:16pm
Hi Stoyo
I would like to know is there any updated version related to animated gif support available.
Thanks and Regards
Hamid
Reply #4 - Sep 20th, 2010 at 6:17am
Hi Hamid,
There isn't animated gif support available, and we don't plan implementing built-in support in the foreseeable future.
