Normal Topic Get Shape\Link by Id. (Read 3320 times)
maor
Apr 12th, 2009 at 10:35am
when i create new shape , i set his unique name.
now i want to get the shape from the diagram by his name.
the function 'Diagram.FindName' do it?
Thanks.
Re: Get Shape\Link by Id.
Reply #1 - Apr 12th, 2009 at 11:31am
FindName and Name are inherited from FrameworkElement, and this worked fine in my test:
ShapeNode shapeNode2 = new ShapeNode(diagram);
shapeNode2.Name = "test";
shapeNode2.Text = "FindName test";
shapeNode2.Bounds = new Rect(10, 10, 100, 100);
diagram.Nodes.Add(shapeNode2);
var found = diagram.FindName("test") as ShapeNode;
if (found != null)
	Debug.WriteLine(found.Text);
maor
Reply #2 - Apr 12th, 2009 at 12:14pm
Its not work.
Diagram.Nodes[0].Name = "1";
Diagram.FindName("1") - return null.
this method also return shape link?
Maor
« Last Edit: Apr 12th, 2009 at 3:25pm by maor »
maor
Reply #3 - Apr 12th, 2009 at 3:25pm
Its not work.
Maor
Reply #4 - Apr 13th, 2009 at 9:16am
Are you calling FindName after saving and loading the diagram? We have not implemented serialization for the name property, so it won't work after calling LoadFromXml.
maor
Reply #5 - Apr 13th, 2009 at 9:23am
What are you mean to saving and loadind the diagram?
when i'm add the nodes to diagram i set tne name property of the node.
after the adding i call to findName to get such shape.
