Normal Topic Delete Key functionality stopped working. (Read 2775 times)
donalmeida
Yay...
Feb 22nd, 2010 at 9:52pm
We had the keyboard delete key functionality working before we upgraded to MindFusion.Diagramming.Silverlight.dll ver 1.3.0.21960. How do I get it to work again?
Thanks, Don Almeida.
Don Almeida.
Re: Delete Key functionality stopped working.
Reply #1 - Feb 23rd, 2010 at 8:47am
We have never had the Del key doing anything in the Silverlight version. Probably you have a KeyDown handler that deletes the selected items - could you check if the event is raised now when you press Del?
donalmeida
Yay...
Reply #2 - Feb 23rd, 2010 at 3:58pm
Hi Stoyan,
This is the C# code.
private void diagram_KeyDown(object sender, KeyEventArgs e)
           if (e.Key == Key.Delete)
               DeleteActiveElement();
and in the markup I set the event handlers as:
KeyDown="diagram_KeyDown"
KeyUp="diagram_KeyUp"
If I set a break point and attach the debugger  it does nto break here at all. and that is why I think the event is not being fired.
thanks Don Almeida
Don Almeida.
Reply #3 - Feb 23rd, 2010 at 4:17pm
Hi Don,
Try calling diagram.Focus() in response to the NodeSelected event.
donalmeida
Yay...
Reply #4 - Feb 23rd, 2010 at 4:24pm
Works like a charm. Thank you Stoyan for the quick reply.
Don Almeida.
Don Almeida.
