Normal Topic How can I get chuilds node on a container (Read 3777 times)
Hamdy Ghanem
Apr 13th, 2009 at 6:44am
I  have a container node
How can I get the  childs node on that container , regarding that my be the container has also a container child
I used ContainsPoint function but it seems very hard to use
is ther any property like nodes to get the chilld of the container node
Hamdy Ghanem
Re: How can I get chuilds node on a container
Reply #1 - Apr 13th, 2009 at 7:05am
I used the new version , digram lite in this topic
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=1238072329;start=20#20
is that ok?
Hamdy Ghanem
Reply #2 - Apr 13th, 2009 at 7:22am
but when trying to use it I have an error
Error1The type 'System.Windows.Controls.ContentControl' is defined in an assembly that is not referenced. You must add a reference to assembly 'System.Windows, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e'.
Reply #3 - Apr 13th, 2009 at 8:32am
You can access the child nodes of a container like this:
if (container.SubordinateGroup != null)
	foreach (DiagramNode child in container.SubordinateGroup.AttachedNodes)
You can't add a reference to a Silverlight assembly to an ASP.NET project. If you need to use Silverlight mode with the updated diagramlite.dll, you will have to rebuild ClientDiagramApp.xap.
Hamdy Ghanem
Reply #4 - Apr 13th, 2009 at 9:01am
SubordinateGroup
is giving me all time null ???????????
Reply #5 - Apr 13th, 2009 at 10:13am
If you are using Silverlight mode with the updated assembly from the DiagramLite message board, the group will be lost after postbacks because we haven't implemented serialization there yet. We'll release NetDiagram 3.0.1 next week and it will support containers in Silverlight mode.
Hamdy Ghanem
Reply #6 - Apr 14th, 2009 at 1:23pm
containerNode.SubordinateGroup.AttachedNodes
this property dioes not get the container of container is child of another container
Reply #7 - Apr 14th, 2009 at 2:55pm
This won't get the children of nested containers if that's what you mean. You could write some method to collect all children of a container that takes a DiagramNodeCollection argument where the children are added, and calls itself recursively when it gets to a nested container.
