Normal Topic Lane Diagram (Read 2383 times)
muthuhamid
Lane Diagram
Apr 13th, 2009 at 7:47am
Hi
Am trying to delete a lane in the lanediagram and i am using the following code to delete the lane and it works fine but it is not removing the nodes and links belongs to that lane.
Can you pls help me in this regards.
Dim grid As Grid = docGanttChart.LaneGrid
Dim hdrToRemove As Header
hdrToRemove = grid.RowHeaders(dbGridTasks.RowBookmark(dbGridTasks.Row))
grid.RowHeaders.Remove(hdrToRemove)
Hamid
Re: Lane Diagram
Reply #1 - Apr 13th, 2009 at 11:04am
You have to manually remove the nodes whose bounding rectangles intersect with the bounding rectangle of the removed row. Here is a code snippet that illustrates how. You have to place this code before removing the row:
Dim r As RectangleF = grid.GetCellBounds(grid(Nothing, hdrToRemove))
Dim toDelete As New List(Of DiagramNode)
For Each node As DiagramNode In docGanttChart.Nodes
      Dim inter As RectangleF = node.Bounds
      inter.Intersect(r)
      If (Not inter.IsEmpty) Then
            toDelete.Add(node)
      End If
Next
For Each node As DiagramNode In toDelete
      docGanttChart.Nodes.Remove(node)
Next
muthuhamid
Re: Lane Diagram
Reply #2 - Apr 13th, 2009 at 12:35pm
Dear Meppy
Thanks for your help.
I tried your code, It works Great... Thanks again.
And if i am removing the first row or middle row then i have problem of remaining nodes which are not belongs to removed lane(other lanes after removed lane), that they all are not in the respective lanes(Actual Parent Lane).
Could you pls help me to move the nodes to the respective lanes after the lane removed.
For example
1. I have 4 lanes with one node in each lane.
2. Now i delete the lane no 2 and its node
3. Now lane 3 will become new lane2 and lane4 will become new lane3, here i want the node of the actual lane3 should move to new lane2 and node of actual lane4 shoud move to new lane3.
Hamid
Re: Lane Diagram
Reply #3 - Apr 13th, 2009 at 2:04pm
The best solution would be to establish a relationship between the nodes and the grid cells they belong to, then handle the Lane.CellBoundsChanged event and ensure that the nodes retain position relative to their associated cells. However, while trying to implement this solution, I have found a bug, resulting in inaccurate values in the argument of the above mentioned event. This bug has been fixed, but until the fix is released, you can use the following code as a workaround. Insert the code right before the row removal:
Dim total As RectangleF
Dim i As Integer = grid.GetRowIndex(hdrToRemove)
For row As Integer = i + 1 To grid.RowHeaders.Count
      Dim rowBounds As RectangleF = _
            grid.GetCellBounds(grid(Nothing, grid.GetRow(row)))
      If total.IsEmpty Then
            total = rowBounds
      Else
            total = RectangleF.Union(rowBounds, total)
      End If
Next
Dim toMove As New List(Of DiagramNode)
      inter.Intersect(total)
            toMove.Add(node)
      End If
Next
For Each node As DiagramNode In toMove
      Dim nodeBounds As RectangleF = node.Bounds
      nodeBounds.Offset(0, -hdrToRemove.Height)
      node.Bounds = nodeBounds
Next
muthuhamid
Re: Lane Diagram
Reply #4 - Apr 13th, 2009 at 3:08pm
Dear Meppy
As you said i inserted the code, but when i delete a row i get the remaining nodes are moved to wrong lanes.
One more thing i would like tell you is each lane will have one main node attached with child node and both the nodes are locked and grouped together.
Likewise all the rows has 1 main node and 1 attached node. some times some row may have only the main node not the child node attached to it.
With this code the attached nodes are moved apart (seperated) from the main node. and i need to move the nodes which are coming after the removed row node.
Here when i remove the 2nd row the node in the first row is moved to the col header area, which is not suppose to.
Could you pls help me in this regards
Hamid
Re: Lane Diagram
Reply #5 - Apr 14th, 2009 at 6:21am
There was a mistake in the above code. Here is the complete, fixed version:
      inter.Intersect(r)
            toDelete.Add(node)
      End If
Next
Next
For row As Integer = i To grid.RowHeaders.Count - 1
            total = rowBounds
      Else
      End If
Next
            If (node.MasterGroup Is Nothing) Then
                  toMove.Add(node)
            End If
      End If
Next
Next
muthuhamid
Re: Lane Diagram
Reply #6 - Apr 14th, 2009 at 6:41am
Hi Meppy
Your help is Great and the code works Superb.
Thanks & Regards
Hamid
