Normal Topic Delete a shape node (Read 2608 times)
Anshul
Senior Member
Delete a shape node
Apr 14th, 2009 at 4:20pm
Hi Stoyan,
On mouse click over the diagram, I want to delete active node.This node is a simple ShapeNode.
How I can do this?
Anshul
Re: Delete a shape node
Reply #1 - Apr 14th, 2009 at 5:05pm
If you want to delete the clicked node, do this from the NodeClicked event handler:
diagram.Items.Remove(e.Node);
or to delete the so-called active item from the Diagram.Clicked handler:
diagram.Items.Remove(diagram.ActiveItem);
Anshul
Senior Member
Reply #2 - Apr 15th, 2009 at 9:39am
when i clicked on diagram,No item behave as activeitem, so i didn't get any activeitem so how can i remove that item which was active item before click on the diagram ???
Reply #3 - Apr 15th, 2009 at 11:08am
Ok, the selection is cleared when you click on the diagram. You could handle the NodeActivated event and save a reference to the last active node in some variable of the form. You might as well call diagram.Nodes.Remove(e.Node) from NodeDeactivated, but NodeDeactivated might be raised in other situations too, and not only when clicking on the diagram.
