Normal Topic LinkDeleted event not firing in ImageMap Mode (Read 1770 times)
jcollins@scires
Apr 14th, 2009 at 8:19pm
Hello, I am using image map mode and have my diagram set up so that when a node is deleted any links attached to that node are deleted as well. The LinkDeleted server side event does not fire when the node is deleted. I also tried looping through any links on the node during the nodedeleted event but they are gone by then. Basically, I just need a way to know at the time the node is deleted what links attached are deleted as well. Thanks.
jay
Re: LinkDeleted event not firing in ImageMap Mode
Reply #1 - Apr 15th, 2009 at 8:48am
We'll upload a fix for this later today.
jcollins@scires
Reply #2 - Apr 15th, 2009 at 1:37pm
Great! Thanks, as always, for the quick replies.
jay
Reply #3 - Apr 15th, 2009 at 3:04pm
This version should fix the events:
https://mindfusion.eu/_temp/netdiag_events.zip
