Normal Topic Disable the default property (Read 1086 times)
muthuhamid
Apr 15th, 2009 at 1:52pm
Hi
Am am using the PropertyGrid control to show the properties of the selected node in runtime and allows user to change the properties. But some times need to disable the some properties, that user should not edit (No Modify allowed) in runtime. How can i do this.?
Pls help me in this regards.
Hamid
Re: Disable the default property
Reply #1 - Apr 15th, 2009 at 2:48pm
You can create a new (wrapper) class around the object displayed in the property grid and supply a reference to this wrapper class instead of the real object. The wrapper class will only expose the properties you would like to be visible in the grid.
There is a more versatile solution available, with a custom TypeConverter class, but it is a bit longer and more complicated.
