Normal Topic Visual Studio Toolbox (Read 2287 times)
dolfandon
Apr 15th, 2009 at 1:58pm
Is there a way to get the control to show up in the Visual Studio Toolbox? I added the dlls but nothing shows up.
Re: Visual Studio Toolbox
Reply #1 - Apr 15th, 2009 at 2:11pm
There are several tabs in the "Customize Toolbox Items" dialog, showing the toolbox content for different types of projects. Did you add the assembly while the "Silverlight Components" tab was selected?
dolfandon
Reply #2 - Apr 15th, 2009 at 2:37pm
Yes, I have the Silverlight Components tab selected and they show up in the choose items dialog but VS does not show them in the toolbox. There are 3 in the tab
Diagram
DiagramHost
TranslateLayer
Oh, here's the caveat here. This is a ASP Dot Net web application that I want to host the control on one of the pages. If I load up a SilverLight application the controls show up in the toolbox.
Reply #3 - Apr 15th, 2009 at 3:19pm
Yep, when you have an ASPX page open in VS, you can add only the so called Silverlight control to the page. You must create a Silverlight project with UserControl that contains the Diagram, build it, and set the resulting .xap file as a Source of the Silverlight control. The SaveLoad example shows that.
